derek42
Mar 30, 2021Aspirant
MR1100. Disappointed
Disappointed in this mobile router. I have tried to connect the M1 to 5 different WiFi routers at work and it won't data offload by WiFi to any. It will connect by ethernet. Sometimes I get a warn...
W1lliam
Mar 30, 2021Virtuoso
to avoid IP address conflicts, you need to configure IP address on M1 over different subnet from the one you have connected via Ethernet. Data offload is working only if you reboot M1 after configured, and Ethernet standby needs to be disabled.
TS-9 antenna port only provide alternative antenna path for lower bands, it needs sort of DIY to export high band antenna connection as attached photo.
