grthomps
Nov 01, 2020Follower
MR1100 Disconnecting from Router Periodically
Hi All,
I have an MR1100 Nighthawk mobile router connected to an Orbi RBR50 via Ethernet. I have the battery for the MR1100 removed and a more powerful brick (3 amp) connected to the USB. This is the primary internet connection for my house.
I have what I'd call a fair signal. There will be periodic disconnects as the tower is a fair distance from my house. My carrier is AT&T and I'm on their unlimited plan.
The problem I'm having is that the MR1100 disconnects periodically and the only way to wake it is to do one of the following:
- Go into the phone app or browser and reboot it.
- Physically unplug it and plug it back in
- Go into the phone app or browser and turn off Domestic Data and then turn it back on.
The disconnects happen multiple times during the day. It seems that if it's not used for a period of time it disconnects. I have no issue with that, it's just that it won't wake up or reconnect when new internet traffic comes along.
These solutions are quite annoying while I'm there. It also means that I can't use any internet connected devices from the house outside of my house effectively.
Here are the settings I've enabled to connect the MR1100 to the Orbi:
- IP Passthru enabled
- DHCP disabled
- Tethering disabled
- Use USB port for charging only
- Ethernet standby disabled
On the Orbi the only thing I changed was the router address to 192.168.0.1 so that I can access the MR1100 separately from the Orbi.
Is there any other setting that can keep Nighthawk connected, or wake it up if there is traffic after it goes to sleep?
- BezerAspirant
Hi, i am having simular setup has yourself, M1 over ethernet to my repeater which is netgear rax 200,
issues i have on m1 it dissconnects about 2 Times a day usually ,always Disconnects usually over night, tried different plug and cable but continues to disconnect regardles, i hoping like you that someone on here will point us both in theright direction To resolve
