judoka20
Aug 09, 2020Follower
Mr1100 Do not sent data to Orbi Router via ethernet.
I need help. I received a new MR1100 hotspot. I can not connect to Orbi Router via Ethernet cable. How can I do it?
1 Reply
Do you have the MR1100 in passthrough mode?
Or the orbi in access point mode?Otherwise you're running 2 routers on the network in router mode and are running a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
