b0rdga
Mar 23, 2018Aspirant
MR1100 does not broadcast wifi
hi guys my hawk suddenly stoping broadcasting wifi i tried every singel idea come in any technation mind - restarted -reseted - power off - playing around with setting but didnt work after all...
- Apr 26, 2018
Thanks all for your advaices
I finaly fix it
just manual update it to 10.25.01.01
and im sorry for the bad spilling
you can download it from here
JasonN
Mar 28, 2018NETGEAR Employee Retired
Hi b0rdga,
Have you tried removing and reseating the SIM card in the device?
Please let me know if this helps. :]
- Jason N
b0rdga
Mar 28, 2018Aspirant
Yes its look good without any problems in dashboard
And i had changed the SIM with more than 3 SIMs different company and also no APN & WIFI
- JasonNMar 28, 2018NETGEAR Employee Retired
Hi b0rdga,
Please contact support for further assistance on this issue.
Let me know the outcome please. :]
http://www.netgear.com/support/contact.aspx
- Jason N
- b0rdgaApr 02, 2018AspirantI had tried it and it gave me a disconnected phone no
- b0rdgaApr 02, 2018AspirantI had tried it and it gave me a disconnected phone number to contact
- JasonNApr 02, 2018NETGEAR Employee Retired
Hi b0rdga,
Did you follow the process of the link I have provided you? What support number did you use? Where are you located?
Please let me know. :]
- Jason N
Hi Chien35,
What is your location? Which provider model is your MR1100?
- Jason N
- Chien35Apr 02, 2018TutorHi Jason,
My location is Cambodia and my MR1100 is Telstra.
Why you ask?
I don't have the problem.
Hi Chien35,
Sorry I thought you were directing the question to the community to be answered.
Hi b0rdga,
I wanted to check in on you and see if your issue was resolved with support?
- Jason N
