MR1100User's avatar
MR1100User
MR1100 does not finish booting
Hello,
I left my MR1100 on overnight and it powered off while I was using it in the morning. Now it fails to boot up past the on screen "NETGEAR" text/logo. I've tried various combinations of the hardware reset button (5 seconds and 10 seconds), removing to reinserting the battery, not using the battery, holding the normal power/top button etc. Nothing seems to reset the device back to working condition. If it helps, the LED is solid amber (not blinking). Any help would be great. Thanks!
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi MR1100User,
    Welcome to NETGEAR Community!
    - Can you still access MR1100 admin page?
    - Can you still see the WiFi network?
    - Did you recharge the battery from a wall socket? from a USB port?
    - Where did you purchase the unit?
    Blanca
    Community Team
    • MR1100User's avatar
      MR1100User
      The admin page is inaccessible and the Wi-Fi network is unavailable. I've tried recharging the battery from various USB sockets ("wall" or otherwise). That seems to work, but not charge status is presented on the display. I bought the unit from AT&T's website and they're already shipping out a replacement unit. I just wanted to see if Netgear knew of any advanced debugging/recovery tricks.
      • Blanca_O's avatar
        Blanca_O
        Hi MR1100User,
        It seems to be a hardware problem on the unit.
        Blanca
        Community Team
