Trlewis
Jun 20, 2021Follower
MR1100 downloaded newer update than the netgear website shows is the latest
I checked firmware. It said i needed to update. It did. New version is NTG9X50C_12.06.39.00. The netgear website says the latest version built in may is 12.06.11. Anyone know why?
JohnPeng
Jun 21, 2021NETGEAR Expert
Your device is AT&T SKU. FW upgrade for AT&T device is managed by AT&T.
The FW version you saw on Netgear support site is for Netgear generic SKU I think. The verrsions are different.
Thanks
cartman7110
Jul 09, 2021Aspirant
I also have this router updated to that firmware. It doe appear forced update.
That firmware also locks out certain APN which was working prior to .39.
Can i update my router (its unlocked, i'm using T Mobile on it and it work with the only working AT&T Broadband APN) so that i can reuse my other APN?
Can i use the generic netgear firmware on this?
Please help!
