mepe
Mar 27, 2020Aspirant
MR1100 ethernet port dies when charger connected
This is a strange one and it's driving me nuts. Started about 3 months ago (just after the warranty expired, natch): The ethernet port dies whenever the charger is connected. To use the e...
- Mar 30, 2020
Usually, Power adapters have a PIN for the device to detect the USB cable is connected to power adapter for charging.
The PA you were using may come with device that doesn't need the PIN in PA.
Thanks
JohnPeng
Mar 28, 2020NETGEAR Expert
MR1100 Ethernet port will be turned off when the device is tethered to your computer. But if you charge MR1100 with power adapter, ethernet will work.
If your MR1100 ethernet port is disabled when you change the device, please let me know what power adapter and USB cable you are using.
Thanks
- mepeMar 28, 2020Aspirant
I'm using the power adaptor and ethernet cable that came with it. (FWIW, I never tether it; have no need to.)
Thanks.
- JohnPengMar 28, 2020NETGEAR Expert
Please let me know your device's SKU name and FW versiona and PRI version on the device. You can find SKU name on the product label under the battery.
Thanks
Thanks.
- IIIGrimReaperIIMar 28, 2020Tutor
Curious if your using the USB as a charging port for your Nighthawk. If you are that is your problem. I have done it and it will reset the hotspot a lot and do weird things as both can be used as a modem port. If your not using ethernet and USB at the same time my apologies for the post and kind ignore it.
- mepeMar 30, 2020Aspirant
Ooops! My bad.
It seems that it was not connected to the charger that came with it; it was connected to a Netgear charger that I thought was the only Netgear charger I had since every other Netgear device I own is 12VDC (no idea where this charger came from). I happened to come upon a Netgear LTE charger while straightening up my bench yesterday; when I connected it to this charger instead, the problem went away. I've had a ping running continuously since about noon yesterday without a hitch.
Which does propose a question: what's the difference between the Netgear USB charger and the Netgear LTE charger that would account for the ethernet failing with the Netgear charger? Both list the same voltage and both provide sufficient current to charge the battery fully from zero and keep it charged.
Thanks.
