mepe
Mar 27, 2020Aspirant
MR1100 ethernet port dies when charger connected
This is a strange one and it's driving me nuts. Started about 3 months ago (just after the warranty expired, natch): The ethernet port dies whenever the charger is connected. To use the e...
- Mar 30, 2020
Usually, Power adapters have a PIN for the device to detect the USB cable is connected to power adapter for charging.
The PA you were using may come with device that doesn't need the PIN in PA.
Thanks
mepe
Mar 28, 2020Aspirant
I'm using the power adaptor and ethernet cable that came with it. (FWIW, I never tether it; have no need to.)
Thanks.
JohnPeng
Mar 28, 2020NETGEAR Expert
Please let me know your device's SKU name and FW versiona and PRI version on the device. You can find SKU name on the product label under the battery.
Thanks
Thanks.
