Drail14me
May 24, 2021Tutor
MR1100 Ethernet port not working
I am unable to get internet to work when I connect a Laptop to the MR1100 via ethernet cable. I can not find anything in the settings to enable the port. Any help would be apprectiated.
michaelkenward
May 25, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but there isn't much similarity between plain routers and mobile hotspots, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
Drail14me
May 25, 2021Tutor
Thank you for the post Michael. I agree with your description of the Netgear Community webpage structure. It's not easily navigated to the unfamiliar. Thanks for asking the Mods to move the message. I'll watch that subforum.
I have checked the manual and it offered no insight.
I also spent almost two hours on the phone with Netgear Tech support with no results. A call to AT&T tech support was the quick solution to "We'll send you another one". Maybe this third one will work.
I'm hoping someone in this community has had the same issue and solved it.
- michaelkenwardMay 25, 2021Guru - Experienced User
These devices seem to have their own special set of quirks. There won't be many people in this section that are familiar with them. Waiting for a response here could leave you disappointed and frustrated.
The good news is that the Netgear moderators seem to be quicker off the mark when a message appears there.
