Jworle's avatar
Jworle
MR1100 Ethernet port will not connect
Ethernet port was working when initially setting up, then then turned off, the blinkie light on my switch turned off for the port that was plugged into the MR1100, all the other devices were showing ...
  • Jworle's avatar
    Jworle
    Jul 29, 2021
    Thanks. It turned out that the original bad ethernet cable must have alrmed the router to turn off the port. I pulled the battery and the power cable then turned it back on, the port was alive again!
