slphelan
Feb 02, 2020Tutor
MR1100 EUS FIRMWARE PROBLEM
I used the below guide to update my router it was successful only one problem. I did not have a sim in the unit when I installed the firmware upgrade now every time I put a sim in the router I does ...
flnsx
Apr 05, 2020Aspirant
slphelanCould you please post a link to the update that worked for your M1? Thanks!
slphelan
Apr 05, 2020Tutor
The links in the guide worked but I had to go to netgear and download the software for my country. The software listed in the guide is not for USA. It was for Austraila if I remember correctlu
