JesseLee72
Sep 18, 2022Follower
Mr1100 factory reset password not valid
I forgot the password for my router. I did a factory reset and tried using the admin password on the label under the battery and it says its invalid. How do I access the router or reset the password if I can't log in? Is there a way to have netgear reset it or look it up but my serial number?
1 Reply
JesseLee72 wrote:
I forgot the password for my router.Wifi or admin?
The manual says
The default password for the admin user name is admin
The usual Netgear admin password is password.
