mjeddajev
Apr 15, 2020Aspirant
MR1100 fails to reestablish the connection after the hang up
MR1100 - Dear netgear support, I'm having problem with connection - due to my operator restrictions, session is disconnected every hour, and solution is to switch data field OFF apply and then p...
Mexoh1To7k
Apr 15, 2020Apprentice
mjeddajev wrote:Mexoh1To7k, Could you please help me at least with the new script?
Label
Sure.
#!/usr/bin/env python3
This scripts monitors the MR1100 to re-enable Data automatically.
This is useful with operators that use PPP and which systematically disconnect
users after a certain period of time.
Works with firmware 12.06.08.00
import requests
import json
import time
import datetime
import sys
if len(sys.argv) < 2:
print("Usage: {} <IP> <ADMIN_PASSWORD>".format(sys.argv[0]))
sys.exit(1)
ip = sys.argv[1]
pwd = sys.argv[2]
timeout = 2
url_base = "http://{}".format(ip)
url_session = "{}/sess_cd_tmp".format(url_base)
url_js_token = "{}/api/model.json".format(url_base)
url_config = "{}/Forms/config".format(url_base)
url_json = "{}/api/model.json".format(url_base)
url_json_success = "{}/success.json".format(url_base)
url_success = "{}/index.html".format(url_base)
def login(r):
try:
api = r.get(url_js_token, timeout=timeout).text
except:
print("Failed to connect to router")
return
try:
api = json.loads(api)
global token
token = api['session']['secToken']
except:
print("Failed to fetch authentification token")
return
data = {
'token': token,
'err_redirect': '/index.html?loginfailed',
'ok_redirect': '/index.html',
'session.password': pwd,
try:
redirect_url = r.post(url_config, data=data, timeout=timeout).url
if redirect_url == url_success:
return True
else:
print("Failed to authenticate, incorrect password?")
return
except:
print("Router failed to respond to authentication challenge")
return
def get_status(r):
try:
json_model = json.loads(r.get(url_json, timeout=10).text)
status = json_model['wwan']['connection']
return status
except:
print("Cannot retrieve connection status")
def reconnect(r):
disconnect = {
'token': token,
'err_redirect': '/error.json',
'ok_redirect': '/success.json',
'wwan.autoconnect': 'Never',
connect = {
'token': token,
'wwan.autoconnect': 'HomeNetwork',
try:
push = r.post(url_config, data=disconnect, timeout=timeout)
if push.url != url_json_success:
print("Failed to disconnect data")
except:
print("Invalid answer from router")
return
try:
push = r.post(url_config, data=connect, timeout=timeout)
print("Failed to reconnect data")
return
except:
def main(dry_run=None):
data_status = None
r = requests.Session()
login_status = login(r)
if login_status != True:
return
else:
data_status = get_status(r)
if dry_run is True:
return True
if data_status != "Connected":
print("Data appears to be disconnected, reconnecting..")
reconnect(r)
nb_tries = 0
while data_status != "Connected" or nb_tries < 3:
time.sleep(1)
nb_tries+=1
if data_status == "Connected":
timestamp = datetime.datetime.now()
timestamp = timestamp.strftime("%Y-%m-%d %H:%M:%S")
print("Reconnection successful {}".format(timestamp))
else:
print("Data is still offline, this should not happen")
if __name__ == '__main__':
try:
dry_run = main(dry_run=True)
if dry_run is None:
sys.exit(1)
else:
print("Connection to router successful. Monitoring disconnections")
while True:
main()
time.sleep(2)
except KeyboardInterrupt:
sys.exit(0)
For the script to run you only need the requests module which you'd usually install with pip in this fashion:
pip3 install requests
I will make a new version of the script to remove this dependency.
maroc84
May 22, 2020Aspirant
Thank you for this script. I used it but my mr1100 was still disconnected. Probably because I run it
with
python script.py ip password &
Anyway. Would you mind if I use parts of your code to build a script that periodically reconnects after 24 h to avoid the forced disconnecting of my provider in the first place. I never wrote other than normal bash script so this would be a more as solid base to do so.
