mjeddajev
Apr 15, 2020Aspirant
MR1100 fails to reestablish the connection after the hang up
MR1100 - Dear netgear support, I'm having problem with connection - due to my operator restrictions, session is disconnected every hour, and solution is to switch data field OFF apply and then p...
Mexoh1To7k
May 24, 2020Apprentice
maroc84Is the Data button checked or unchecked when you are disconnected?
The script appears to correctly detect that Data has been disabled. Perhaps it fails to re-enable it.
maroc84
May 29, 2020Aspirant
Sorry for my late reply.
So your script was working fine. I found out I ran my MR1100 in bridge-mode (IP-Passthrough) what wasn't working correctly therefor I could reach the IP of it without problems. This may be the reason the script couldn't restart the connection if lost.
After setting the MR1100 to normal router-mode and my router behind it as a IP-client it worked flawless.
So other news. Yesterday I got a firmware update to 12.06.12.00 and had no change log so I disabled your script for testing purposes and YEAY - without your script as active service on my raspberry py 4 the connection was rebuild after provider-site disconnection!
hopefully this wasn't just some strange mistake ;)
