DieselTrucker87
Feb 01, 2020Follower
MR1100 Fails To turn on
When you plug in device with battery or not the NetGear screen lights up and turns off a few times with the orange led light in the corner and fails to boot up fully. Pushing the reset button for mor...
JohnPeng
Feb 02, 2020NETGEAR Expert
Yes. Most likely, the device need to be replaced.
Thanks
