Mo3lim
Apr 24, 2018Aspirant
MR1100 firmware & wireless slowness
I purchased the MR1100 router around April 7th. It was working perfectly with old firmware which is NTG9X50C_lO.12.02.01 but I figured they have pushed out an updated and router has been horrible e...
JasonN
Apr 25, 2018NETGEAR Employee Retired
Hi Mo3lim,
Thank you for posting in the community. Can you confirm which M1 provider model is yours? (AT&T / Telstra / etc.?) Have you done a factory reset on your device after the update? If not, then please proceed with the reset.
Please let me know if that fixes the slowness. :]
- Jason N
Mo3lim
Apr 25, 2018Aspirant
I'm usuing Telstra unlocked version , yeah I have done the factory reset twice but unfortunately nothing changed , I have tried to operate the device with & without battery but no luck
Also playing with Wifi settings didn't work out
Hopefully someone can help me to find an old firmware or solve my slowness issue
- JasonNApr 26, 2018NETGEAR Employee Retired
Hi Mo3lim,
Have you tried reupdating to the same firmware?
Please follow these steps and let me know it works for you. :]
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
- Jason N
