Mo3lim
Apr 24, 2018Aspirant
MR1100 firmware & wireless slowness
I purchased the MR1100 router around April 7th. It was working perfectly with old firmware which is NTG9X50C_lO.12.02.01 but I figured they have pushed out an updated and router has been horrible e...
Mo3lim
Apr 25, 2018Aspirant
I'm usuing Telstra unlocked version , yeah I have done the factory reset twice but unfortunately nothing changed , I have tried to operate the device with & without battery but no luck
Also playing with Wifi settings didn't work out
Hopefully someone can help me to find an old firmware or solve my slowness issue
JasonN
Apr 26, 2018NETGEAR Employee Retired
Hi Mo3lim,
Have you tried reupdating to the same firmware?
Please follow these steps and let me know it works for you. :]
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
- Jason N
- Mo3limApr 28, 2018AspirantI have done the reupdate but till now no change to be mentioned slowness still there
- JasonNMay 02, 2018NETGEAR Employee Retired
Hi sale7n,
I will PM you for further assistance. :]
- Jason N
- Mo3limMay 03, 2018Aspirant
This is the information you requested I hope it will help
Nighthawk MI
Hardware Version
1.0
Firmware Version
NTG9X50C_l0.25.01.01
GUI Version
MRI HDATA_04.01.58.00
PRI Version
03.22
Bootloader Version
Firmware Build Date
2018/03/28
