coreylbailey
Oct 03, 2019Follower
MR1100 Firmware Boot Loop
Device was not working out of the box,
Tried calling Support as they were not able to help me as I bought the device from eBay.
Was able to use a Static IP and login to the device with Ethernet.
Went to upgrade the Firmware as the Support Person said if I could get into it try updating the Firmware.
Did that and the device is now showing the Ciricle Logo and then Netgear pops up for a second and reboots again.
Anyone able to get back in or am I stuck with a Bricked device?
1 Reply
There's a factory reset option if something was messed up during setup. worth a shot if you're stuck in a boot loop.
