aardvark54
Jul 15, 2022Follower
MR1100 Firmware Update Issue
I am trying to update my Netgear Nighthawk M1 to the latest firmware, and I keep getting this error: "The session could not be completed and the device will automatically retry the check for an avail...
Blanca_O
Jul 21, 2022NETGEAR Employee Retired
Hi aardvark54
Welcome to NETGEAR Community!
Please provide the device SKU (e.g. MR1100-100NAS). This can be checked on the box of the product or on the barcode label
Is the device online?
Have you tried factory resetting the device?
Please check M1 signal strength indicator to ensure if device reception is good.
Blanca
Community Team
icaruspony
Aug 07, 2022Luminary
Blanca,
I am having this problem, too.
This is a repeat of the exact problem that happened in 2019 that you fixed before as it was a change on AT&T's network (see at https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Netgear-Nighthawk-MR1100-2A1NAS-Firmware-Update-Error/td-p/1689428 )
MR1100-1A1NAS_04.01.70.23
NTG9X50C_12.06.39.00
Using AT&T SIM
Speedtests are fine.
Error:
"The session could not be completed and the device will automatically retry the check for an available update."
Problem has been going on for at least a month.
- magickboxSep 13, 2022Initiate
I am having the same issue. Connectivity is spotty as well when on the road. Thought perhaps it needed a firmware update but get the same error "The session could not be completed and the device will automatically retry the check for an available update." Have tried logging on and off but the error remains. My specs are:
Firmware Version
Build Date: 2021/05/10
Hardware Version: 1.0
PRI Version: 06.14
GUI Version: MR1100-1A1NAS_04.01.70.23
Device Info
Nighthawk LTE Mobile Hotspot Router
Carrier: AT&T
Signal Strength: Good
Battery: 94%
- dptcmSep 16, 2022Aspirant
I am literally in the same boat as everyone else here, same model, same firmware, same everything including this error.
I had actually been getting this error for a few months but broadly the internet was still usable so I didn't take the time to investigate however the last few days the internet has been bad to the point that it's affecting my ability to work from home. What exactly needs to happen here for the updates to work? Seems like it would be pretty straightforward for a company that has been making networking devices for over 20 years.
- magickboxSep 26, 2022Initiate
Is anyone monitoring this community? I have heard nothing back. Crickets.
