frankie2016's avatar
frankie2016
Follower
Jun 23, 2020
MR1100 firmware upgrade
Trying to upgrade firmware from NTG9X50C_12.06.02.00 but unable to find .spk file  (http://www.downloads.netgear.com/files/GDC/MR1100/MR1100NAS_V12.06.11.00_00.zip) - will only give my a zip file to download. When I check for updates in settings, I am told insufficent data to download (I have 45 gb) and no longer get the option to check for updates. I tried uploading the .zip version - told me had to have the .spk version.  Is it possible to update. Sorry to say that if I get ansers telling me to go hither and thither and download this and then that, I will just have to throw my hands in the air and forget it! Ta.
  • Hi frankie2016
    Welcome to NETGEAR Community!
    Kindly unzip or uncompressed the Zip file for you to have the .spk file / firmware. Once done, access MR1100 settings page again for you to upload the .spk file / firmware.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi frankie2016
    Blanca
    Community Team
