sena71
Jul 28, 2019Tutor
MR1100 Firmware
What software tool does the M1 primarily work with when updating manually using the AT!BOOTHOLD command? I am using fdt.exe and the QDLOAD COM serial port shows up in Device Manager but fdt fails to communicate with the modem. I also have the AT!ENTERCND password and the algorithm to unlock engineering mode with AT!ENTERUNLOCK but I have still yet to find a way to do something as simple as upload firmware.
For note, it is currently running the AT&T firmware which does not allow for upload via WebUI. I intend on uploading compiled firmware based on the official open source code provided by Netgear.
- sena71Tutor
Also, what else must I do to enable ADB and the TFTP server? They been enabled via the AT!CUSTOM="ADBENABLE",1 and AT!CUSTOM="TFTPSERVERDISABLE",0 commandS but it still does not show up via adb or fastboot and i cannot communicate with it via TFTP.
- Big7BossTutor
Hello,
Hope you are doing well. I saw you had de password for at!entercnd command. Mind sharing? Im having a hard time looking for it.
Thanks.
