FirstCup
Jun 19, 2021Guide
MR1100 FW update/log in
MR1100 ATT, I have used this for a few years, been okay. Yesterday I updated the FW by logging on in my browser. 192.168.1.1 which brought up all the setting, etc. I went to the FW update and it show...
- Jun 21, 2021
Please clear your browser cache to see whether the issue can be address.
Thanks
michaelkenward
Jun 20, 2021Guru - Experienced User
That's a Mobile Router. You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here. But there is not much in common between the MR1100 and Nighthawk routers so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
JohnPeng
Jun 21, 2021NETGEAR Expert
Thanks
