wolfman_4_ever
Nov 21, 2020Aspirant
MR1100 incorrect wifi mobile router in netgear ios app
I get incorrect mobile router in the netgear ios mobile app.
If I factory reset the device it works fine but as soon as i change the ip address of the nighthawk to something other than 192.168.1.1, lets say 192.168.100.1, the app will no longer connect. I can access the device fine through a browser.
This appears to be an ongoing issue that only seems to be solved setting the mr1100 back to the factory ip address of 192.168.1.1.
Please Advise.
Thanks.
Please Advise.
Thanks.
1 Reply
You have posted your message in the section of this community given over to
Apps and Services. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I have asked the Netgear moderator to move your message.
