acelis's avatar
acelis
MR1100 IP Passthrough broken (possible bad AT&T FW update?)
I've been having an issue with an MR1100 AT&T variant that I recieved as a demo where I can't put the device in bridge mode or "IP passthrough" as it's called in the device.  I might have caused the issue myself by updating the FW to NTG9X50C_10.20.05.02 as this seems to have been discussed on the AT&T forums (https://forums.att.com/t5/Other-Phones-Devices/Netgear-Nighthawk-M1-mr1100-Latest-Update/m-p/5365005).
I posted the following post there with the same issue (https://forums.att.com/t5/Other-Phones-Devices/Netgear-MR1100-does-not-work-with-IP-Passthrough-Enabled/m-p/5367956) and tried different combonations of reseting the device, putting it in IP passthrough with and without DHCP, DNS, etc enabled/disabled.  Called AT&T support and the rep suggested it was my wireless plan... yet he couldn't see it... so i seriously doubt it was that.
I hate going to a different forum to ask for help, but I really have to try to get this working since my days are limited on this demo provided to me, and I'm not getting any help from AT&T.
Anyone know a way to retrieve older firmware and downgrade the device to see if that's it?
Any other thoughts, suggestions?
  • Update:  Called Netgear support and they confirmed there is an issue with IP Passthrough on the MR1100 running FW 10.20.05.02.  There is apparently a queue of other people that have called about the same issue, and I have a case opened for them to call me back once a firmware fix is in place.  Unfortunately I have a feeling that won't be until after my demo expires.
    I wish Netgear would have made some sort of official statement or notice on the product support page... but oh well.
    We'll see.
    We'll see.
    • pcjackson06's avatar
      pcjackson06
      Add me the queue.  Very annoyed.  Upgraded firmware, broken pass through.
      • Brittrix's avatar
        Brittrix
        Same issue here. Enabling Pass-Thru mode (due to the fact that I have my own WI-FI router with its own DHCP), results in either the modem never coming back after the setup, or if it does eventually come back, it starts using a class A address (10.xxx.xxx.xxx) instead of the assigned class C address (192.168.1.xxx). Worse yet, it keeps changing its own address.
        I simply want the MR1100 to act as a pure LTE modem, no DHCP, no WIFI, and no dynamic addressing.
