sgp001
Aug 23, 2021Tutor
MR1100 Loses Carrier Aggregation
Hello, My model : MR1100-100EUS_01.01.80.00 with NTGX50C_12.06.11.00 My provider: Austria A1 When I reboot the device or when I change the band configuration, I get CA. For example: Curren...
sgp001
Aug 25, 2021Tutor
Dear Support! Can you help with this issue?
Kind regards
- sgp001Sep 02, 2021Tutor
Dear JohnPeng , problem is still there.
The provider confirmed that they switch off Carrier Aggregation due to power saving reasons. Also providers in Germany (T-Mobile and Vodafone) are testing this behaviour. For mobile phones it does not matter (because they reconnect to CA if needed). But the MR1100 does not reconnect back to carrier aggregation and stays on the first band.
In the meantime I wrote a small bash script which checks if CA is still connected. If not, then I switches bands to have CA again. I let it run on an hourly basis.
Can you help us? Running this script is not a permanent solution.
#!/bin/bash # Get status of MR1100 via telnet # Save the results in the variable output1 output1=$(( echo open 192.168.1.1 5510 sleep 1; echo "at!gstatus?"; sleep 1; echo "exit" ) | telnet ) echo $output1 # Match the results of at!gstatus with the expected connection pattern # In this case check if twice connected to B3 # If yes then exit this script if [[ "${output1}" =~ B3(.|\n)*B3 ]]; then echo "matched - all good" exit 0 fi sleep 3; # Connection pattern is not in line with expected behaviour # First check which band is currently selected # We switch here between band=00 --> auto and the band=03 # Define variable to select the custom band band_selector="03" # Check which band we are connected to right now output2=$(( echo open 192.168.1.1 5510 sleep 1; echo "at!band?"; sleep 1; echo "exit" ) | telnet) echo $output2 # Band 3 has the custom name LTE B3. In case band=03 is connected switch over to AUTO # and vice-versa if [[ "${output2}" =~ LTE[[:blank:]]B3 ]]; then band_selector="00" echo "B3 - switche auf AUTO" fi sleep 3; # Now switch the band to the opposite # Means if band=03 then switch to band=00 and vice-versa output3=$(( echo open 192.168.1.1 5510 sleep 1; echo "AT!BAND=$band_selector"; sleep 5; echo "at!gstatus?"; sleep 2; echo "exit" ) | telnet) echo $output3 # Send the results pers mail /usr/sbin/ssmtp your-email-addr@gmx.net <<EOM Subject:Status MR1100 aktualisiert $output1 ****************************** $output2 ****************************** $output3 EOM exit 1- JohnPengSep 02, 2021NETGEAR Expert
Thanks all for reporting the issue. We were not aware of this before.
Will investigate and get back to you soon. If needed, we will release a MR to fix the issue.
Thanks
John
- davide84Sep 18, 2021AspirantI have the same problem in the US with ATT and the MR5100.
After some hours or so, my mr5100 stops doing carrier aggregation and I get stuck with slow speeds.
Only way to get it back to carrier aggregation is to reboot the router. Very annoying.
