sgp001
Aug 23, 2021Tutor
MR1100 Loses Carrier Aggregation
Hello, My model : MR1100-100EUS_01.01.80.00 with NTGX50C_12.06.11.00 My provider: Austria A1 When I reboot the device or when I change the band configuration, I get CA. For example: Curren...
JohnPeng
Sep 02, 2021NETGEAR Expert
Thanks all for reporting the issue. We were not aware of this before.
Will investigate and get back to you soon. If needed, we will release a MR to fix the issue.
Thanks
John
davide84
Sep 18, 2021Aspirant
I have the same problem in the US with ATT and the MR5100.
After some hours or so, my mr5100 stops doing carrier aggregation and I get stuck with slow speeds.
Only way to get it back to carrier aggregation is to reboot the router. Very annoying.
