jazdale
May 10, 2019Aspirant
MR1100 LTE - VPN freqently reconnects using wireless
I recieved a couple MR1100 LTEs to test for our company.
It is faster and works great with ethernet cable and a laptop.
However, our users also need to simutaneously connect an ipad with VPN to perform their job.
The ipad uses Cisco anyconnect VPN.
Testing 3 different ipads on 2 different MR1100s, all produced the same results.
The VPN was reconnecting every 3 to 30 seconds.
This is true using 2.4 or 5 GHz mode.
When connected to a laptop with ethernet connection, the VPN is stable.
Firmware setups say i'm on the latest with NTG9X50C_12.05.05.00
I'd love to get this resolved.
It would mean purchasing 2 dozen more for my staff.
- jazdaleAspirant
I'm curious if there is a firmware update that addresses this issue.
- dan_vtAspirant
Having the same issues. Wondering if you ever heard back from anyone on how to fix the issue?
- mcanderson24Aspirant
I'm also experiencing the same issue - connected to Cisco VPN and it will drop connection / partially drop connection to VPN long enought to disconnect everything. All other connections work fine. Running NTG9X50C_12.05.05.00 as the firmware. It would be great if we could get this resolved.
