Al00000
Oct 26, 2019Tutor
MR1100 M1 Nighthark Reboots andter Firmware Update
I've had this MR1100 for a couple of weeks and it has worked well. I run it from the USB C, so I remove the battery, as recommended. I don't know why, in 2019, the battery should be removed. ...
- Oct 30, 2019
No issues with leaving the battery in. The latest release will resolve a reset that some customers saw while running without the battery. Also the latest release addreses charging and can now allow users to leave the battery in while plugged in.
Oxygene
Oct 27, 2019Apprentice
There is another update via 192.168.1.1
- LTEGuyOct 28, 2019Star
the latest update will resovle the issue of running with and without the battery. So best way to proceed would be to leave the battery in the M1 and select "Check for Updates". Allow the update to occur and you can then continue to use the device with the battery left in the device. Or remove it if you prefer, either will work fine.
- Al00000Oct 29, 2019Tutor
Thanks LTEGuy.
Can you please explain the deal with leaving the battery in, whilst on charge.
Is it bad to do this, or does it just shorten the battery like by a little bit.
It would be convenient just to leave it in; but it tells me to remove the power, when it is fully charged.
- LTEGuyOct 30, 2019Star
