Al00000's avatar
Al00000
Tutor
Oct 26, 2019
MR1100 M1 Nighthark Reboots andter Firmware Update
I've had this MR1100 for a couple of weeks and it has worked well.   I run it from the USB C, so I remove the battery, as recommended. I don't know why, in 2019, the battery should be removed.   ...
  • LTEGuy's avatar
    LTEGuy
    Oct 30, 2019
    No issues with leaving the battery in.  The latest release will resolve a reset that some customers saw while running without the battery.  Also the latest release addreses charging and can now allow users to leave the battery in while plugged in.
