Al00000
Oct 26, 2019Tutor
MR1100 M1 Nighthark Reboots andter Firmware Update
I've had this MR1100 for a couple of weeks and it has worked well. I run it from the USB C, so I remove the battery, as recommended. I don't know why, in 2019, the battery should be removed. ...
- Oct 30, 2019
No issues with leaving the battery in. The latest release will resolve a reset that some customers saw while running without the battery. Also the latest release addreses charging and can now allow users to leave the battery in while plugged in.
Al00000
Oct 29, 2019Tutor
Thanks LTEGuy.
Can you please explain the deal with leaving the battery in, whilst on charge.
Is it bad to do this, or does it just shorten the battery like by a little bit.
It would be convenient just to leave it in; but it tells me to remove the power, when it is fully charged.
LTEGuy
Oct 30, 2019Star
