boleropilot
Mar 14, 2017Aspirant
MR1100 manual corrupt
cannot download the MR1100 manual - download hangs near the end and states "download corrupt"
- Mar 15, 2017
JUST KEPT TRYING - each time it downloaded a bit more and finally i got the whole file and saved it - wierd....
stevesw
Mar 14, 2017NETGEAR Expert
Can you please confirm the download link that you used.
I tried downloading all 3 documents from the following page and they all worked for me.
https://www.netgear.com/support/product/MR1100.aspx?cid=wmt_netgear_organic#docs
Steve
- boleropilotMar 15, 2017Aspirant
g'day Steve
the message i get is "the file is damaged and could not be replaced"
the link i am using is: http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf?cid=wmt_netgear_organic
BP
i just tried the link you posted above and i get the same thing...
