W1lliam
Apr 08, 2018Virtuoso
MR1100 manual DNS is not working
My firmware is NTG9X50C_10.25.01.00, manual DNS is not working, the client stayed with MR1100’s IP address even if I have manual DNS set.
- Apr 09, 2018
Hi W1lliam
As schumaku described Auto receives the IP address of your isp DNS during login negotiation to the cell. When you set manual it uses the DNS at the IP you nominate. I personally use googles 8.8.8.8 and 8.8.4.4. Within the M1 router itself, that is all you can do regards the settings. If you want to access DNS directly without using the M1 as a relay, you can set the IP manually in windows(that is not use DHCP on your PC) and also set the DNS manually at the pc in windows as well.That way the M1 is not acting as a DNS relay and your PC will talk directly to the DNS you want to use. Let us know if that sorts the domain resolution timeouts.
AoC
Apr 08, 2018Guide
Hello!
How did you check the DNS server used by your client? You can check it on : https://www.dnsleaktest.com/ , and select "standard test". Let it run and you should see under column "ISP" whose DNS server was used. If that corresponds with the dns server assigned on the MR1100 settings, everything is ok. The IP adresses shown on the dnsleaktest might vary from the adresses shown on the MR1100 settings page.
But if you wan't to override this process, you must set DNS address manually from your client/device. For example, on Windows, it's done throught networking settings. Further information can be found from here: https://support.microsoft.com/en-us/help/15089/windows-change-tcp-ip-settings
Apparently, it's not possible to set up IPv6 DNS servers on MR1100. You can only switch IPv4 DNS servers on the web configurator. IPv6 DNS servers must be set up manually from the client device.
W1lliam
Here is the snapshot for my client which associated with MR1100, as you can see its DNS is set to the mobile router (192.168.99.1), also attached my settings on MR1100. Seems MR1100 does not reply DHCP request with proper DNS settings on the device.
William
