W1lliam
Apr 08, 2018Virtuoso
MR1100 manual DNS is not working
My firmware is NTG9X50C_10.25.01.00, manual DNS is not working, the client stayed with MR1100’s IP address even if I have manual DNS set.
- Apr 09, 2018
Hi W1lliam
As schumaku described Auto receives the IP address of your isp DNS during login negotiation to the cell. When you set manual it uses the DNS at the IP you nominate. I personally use googles 8.8.8.8 and 8.8.4.4. Within the M1 router itself, that is all you can do regards the settings. If you want to access DNS directly without using the M1 as a relay, you can set the IP manually in windows(that is not use DHCP on your PC) and also set the DNS manually at the pc in windows as well.That way the M1 is not acting as a DNS relay and your PC will talk directly to the DNS you want to use. Let us know if that sorts the domain resolution timeouts.
W1lliam
Here is the snapshot for my client which associated with MR1100, as you can see its DNS is set to the mobile router (192.168.99.1), also attached my settings on MR1100. Seems MR1100 does not reply DHCP request with proper DNS settings on the device.
William
MicW
Apr 09, 2018Luminary
Hi W1lliam
The M1 is acting as a DNS relay to the DNS you set manually. So instead of using the DNS your ISP supplies when you log in to the cell , the M1 should be refering to DNS at the IP you manually set. As AoC pointed out, the test at dnsleak should confirm where you are actually getting your name resolution from.
