W1lliam
Apr 08, 2018Virtuoso
MR1100 manual DNS is not working
My firmware is NTG9X50C_10.25.01.00, manual DNS is not working, the client stayed with MR1100’s IP address even if I have manual DNS set.
- Apr 09, 2018
Hi W1lliam
As schumaku described Auto receives the IP address of your isp DNS during login negotiation to the cell. When you set manual it uses the DNS at the IP you nominate. I personally use googles 8.8.8.8 and 8.8.4.4. Within the M1 router itself, that is all you can do regards the settings. If you want to access DNS directly without using the M1 as a relay, you can set the IP manually in windows(that is not use DHCP on your PC) and also set the DNS manually at the pc in windows as well.That way the M1 is not acting as a DNS relay and your PC will talk directly to the DNS you want to use. Let us know if that sorts the domain resolution timeouts.
W1lliam
Apr 09, 2018Virtuoso
Hi MicW,
If MR1100 would work as DNS relay, then what is the difference for Auto and Manual setting? I would run into problem where the domain could not be resolved, or resolving for quite a long period of time, when trying to surf web sites with my browser. When I run into this issue, just reboot MR1100 and it works again. The reason that I am doing this "Manul" DNS setting is to send DNS resolving request to the DNS server directly instead of MR1100, is there anyway to do this or it is done by design and no way to change this? Thanks
William
MicW
Apr 09, 2018Luminary
Hi W1lliam
