Webbwulf
Feb 22, 2020Tutor
Mr1100 mobile broadband disconnected
My mr1100 using simnetwireless says mobile broadband disconnected. Apparently netgear and tmobile are working on a fix and anyone confirm this? Any fixes that I'm unaware of would help. I'm in a rura...
- Mar 14, 2020
As we found out that if you are using a data plan for tablet from T-Mobile, the SIM would not work any more with M1. You need to ask T-Mobile to change your plan for Mobile Hotspot for your SIM to work again on M1.
Thanks
Blanca_O
Feb 26, 2020NETGEAR Employee Retired
Hi Webbwulf
Kindly try the following APN settings if this works for you:
APN Name : Fix
APN : b2b.static
PDP and PDP Roaming : IPv4
@melwiththecell shared this information and this resolved the issue:
Blanca
Community Team
- Blanca_OMar 01, 2020NETGEAR Employee Retired
Hi Webbwulf,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- mikedrMar 07, 2020Aspirant
I just tried that with one of my M1's and it did not work. It just said connected on status then disconnected. I have 2 of these devices and 2 lines that i am paying for and they are currently useless. Also i was not able to downgrade bios, so both are now upgraded to the latest version.
- JohnPengMar 08, 2020NETGEAR Expert
Sorry for the inconvenience. Could you please provide the following information?
SKU name: Is it MR1100-100NAS
Where did you buy it?
Which carreir you are using? T-Mobile or AT&T
Did you get the SIM card from carrier's retail store or wholesaler?
What is the FW version on your device now?
If possible, please provide the model.json log following the steps below.
Step 1: Open 192.168.1.1 on your browser.
Step 2: Input the account and password if necessary (admin/password)
Step 3: type 192.168.1.1/model.json
Step 4: Select everything (Ctrl + A), then copy-paste it to a private message to me.
I will send you a private message and you can reply to me with the log.
Thanks
