Webbwulf
Feb 22, 2020Tutor
Mr1100 mobile broadband disconnected
My mr1100 using simnetwireless says mobile broadband disconnected. Apparently netgear and tmobile are working on a fix and anyone confirm this? Any fixes that I'm unaware of would help. I'm in a rura...
- Mar 14, 2020
As we found out that if you are using a data plan for tablet from T-Mobile, the SIM would not work any more with M1. You need to ask T-Mobile to change your plan for Mobile Hotspot for your SIM to work again on M1.
Thanks
danman9
Mar 14, 2020Tutor
I am having the same issue with T-Mobile. The APN settings didn't help either.
JohnPeng
Mar 14, 2020NETGEAR Expert
Thanks
- Tr00per6960Mar 30, 2020Aspirant
Hi John,
So is AT&T blocking the M1 like T-Mobile? My router was working just fine the other day then it disconnected and I haven't been able to reconnect. Will I need to purchase another SIM card or change the plan with them?
