Lb15
Feb 27, 2021Tutor
MR1100 New Battery Not Charging
I have been using this model for about 2 years. Just recently the battery it came with started to swell, so I bought a new one online. It would not charge (showed an empty battery icon) so I returned ...
michaelkenward
Feb 28, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
