Lb15
Feb 27, 2021Tutor
MR1100 New Battery Not Charging
I have been using this model for about 2 years. Just recently the battery it came with started to swell, so I bought a new one online. It would not charge (showed an empty battery icon) so I returned ...
Sauce73
Apr 12, 2021Aspirant
I’m having the exact same issue. Have you had any luck?
Lb15
Apr 13, 2021Tutor
Nope. I've been using it plugged in.
- Blanca_OApr 14, 2021NETGEAR Employee Retired
Kindly access MR1100 settings page and check TETHERING section.
Go to Setup > Router Setup > Tethering > select Charge only
Blanca
Community Team- Sauce73Apr 15, 2021AspirantSo I’ve changed tether settings to charge only, still no luck. I even returned the first battery and got another brand new battery. It does the same thing. This is all I get. The original battery still works, except it looks like it’s about to explode. It is so swollen that it won’t stay in and can’t get the back cover on. And it doesn’t seem to want to work with no battery at all. ??? I don’t understand why both brand new batteries won’t do anything but the old gassed up swollen one still works.
- Blanca_OApr 18, 2021NETGEAR Employee Retired
Hi Sauce73
May we please have the following information for both the original and the replacement battery:
Battery Model
Voltage
Min. Capacity
P/N
Kindly provide as well the M1 SKU (e.g MR1100-100NAS) and firmware version.
Stop using the original (swollen) battery if it appears damaged, swollen, or compromised.
Blanca
Community Team
