Ottocinque
Aug 24, 2023Aspirant
mr1100 night hawk m1/reload problem/TFTP method/ .spk instead .img or .chk
Hi, MR1100 night hawk M1 used for 2 years, all ok 2,4 ghz except (5Ghz), now problem perpetual reload and blanking blue/amber light or fix amber. Reset not working. Tried to use TFTP method on Mac b...
schumaku
Aug 25, 2023Guru - Experienced User
Ciao 85,
Neither .spk nor .img or .chk need to be expanded - just upload by tftp ...
or
- OttocinqueAug 27, 2023Aspirant
Hi Schumaku, thanks for the reply. Using my MacBook Air, on TFTP mode (terminal mode) seems I need to expand the update. Problem is, apple doesn't expand .spk...
Looking for an update able to expand and drop on TFTP. Regards
- schumakuAug 27, 2023Guru - Experienced User
It's in no way a compressed archive, nothing to expand. tftp would not do it anyways - it's a simple direct file transfer. Unpacking the zip archive should net be an issue, isn't it?
- OttocinqueAug 30, 2023Aspirant
Thanks again, yes, no problem with the Zip.
I will try again in TFTP mode. Or with a PC if not working.
No other solution to restart ?
Its a shame, that the MR1100 is blocked on reboot mode with no reason...
