bwcacanoe
Apr 20, 2018Aspirant
MR1100 Nighthawk battery and signal strength question
I just bought an AT&T Nighthawk LTE Mobile Hotspot MR1100. I know the manual says it will cut down on power to the battery if left plugged in, but I keep getting messages to Unplug the unit. For long...
bwcacanoe
Thanks Jonathan, that was the information I was looking for and was very helpful. When I go into the hot spot from my browser or the app, I just get things like "signal strength fair" but no numbers as to dbm. I've gone into settings looking at network etc. but can't find any real numbers.
JSchnee21
Apr 20, 2018Virtuoso
Great. Keep digging, it's definately in there on one of the network or advanced status pages. I don't have the device in front of me so I cannot tell you how to get there at the moment (sorry).
But once of the pages definately has LTE signal. Mine is typically -91 to -105dB at home.
-Jonathan
- jpr78Apr 20, 2018Tutor
Looks at the pics in this post. You want to go to the Diagnostic tab to see the info you're looking for.
Settings > AT&T Wi-Fi Status > Diagnostics
- bwcacanoeApr 20, 2018Aspirant
You folks are the best. Here's what I've found:
If you go in on the browser and open 192.168.1.1, you get the "opening screen". From there select "Settings" and then "Diagnostics" and on this screen you get the dBm numbers.
If you go in on the Netgear app (iOS), you go to "Settings", and then "Network", and then "Advanced Info", and on this screen you get the dBm numbers.
I can't thank you enough for helping me work through this and find the information I need to position and gain the most benefit from the Nighthawk LTE Router. I have my anker charger on order and a longer USB-C cable.
- JSchnee21Apr 20, 2018Virtuoso
Awesome,
My/Our pleasure. One other general comment. The Wifi range on the MR1100 is not great (even on the "Long" setting). If you need more range run Ethernet to a dedicated wireless access point and/or Ethernet switch centrally located in your space.
For example:
Switch (don't get the POE version, some say the MR1100 doesn't like to see the voltage)
WAP:
If you cannot easily run Ethernet, MOCA also works well if you have COAX available.
The jury still seems to be out on the best antenna for the TS9 connections and the extent to which they do or do not help. In general cheap consumer/prosumer antennas seem to do little or make things worse. Some have had good success with professional ($$$) directional, MIMO antennas on masts. Others tend to have a lot of band hopping.
Best,
Jonathan
