djt2020's avatar
djt2020
Guide
Aug 23, 2020
MR1100 Nighthawk M1 Compatibility with Home Routers Model?
MR1100 Nighthawk M1Compatibility with Home Routers Model?
If you’ve used the M1 long you may have noticed that it doesn’t play well with other routers via the Ethernet port. With the M1 set to IP Passthrough on and the DHCP turned off what models of router have you found to be compatible? I think this would be a valuable resource for many people. Thanks for your input.
I’ll begin the list with the TP Link Archer A7 AC1750.
No RepliesBe the first to reply
