AndyOakeley
Jul 22, 2020Follower
MR1100 (Nighthawk M1) Manual Firmware Update - Telstra
Hi, I have a Telstra Nighthawk M1 (SKU: MR1100-1TLAUS) that is stuck on firmware 10.25.01.01 and the OTA update is not working. Does anyone have a link to the 12.06.08.00 (or newer) Telstra F...
- Jul 28, 2020
Update to my last comment. Previously, after checking and detecting updates available I'd immediately tried installing; this was failing. Before going to be last night I tried one more time of checking for updates and then leaving it. When I checked this morning it was asleep, but after waking it up it downloaded and installed successfully. So, not sure if it just needed some time to think about things or if Netgear fixed something in the background.
Also, I stumbled upon this link: http://www.downloads.netgear.com/files/GDC/MR1100-1TLAUS/MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04.secc.spk , provided by W1lliam over in this thread: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/frimware-update-problem/td-p/1741156 . As my M1 is now on 12.06.08.00 I didn't get a chance to test installing this one, but it might help others if they're stuck on a really old version.
Thanks to Netgear techs if they fixed something in the background.
Brettski1977
Jul 27, 2020Tutor
I'm in the same boat. Any Netgear Forum moderators able to provide some input please?
Currently stuck on 10.25.01.01 on my newly purchased second hand model but my original is on 12.06.08.00 so I know it's available somewhere.
Cheers
icarusbon
Jul 27, 2020Aspirant
I am having exactly the same problem. Glad if Netgear can provide update method with WebUI.
