gokusupa
May 18, 2022Follower
Mr1100 nighthawk M1 will not factory reset
Nighthawk MR1100 M1 No factory reset option is available under settings No ability to update firmware Holding reset button for 5,10,20,30,60,120 seconds yield no results, the custom settings re...
aknight731
Jan 05, 2023Initiate
I have a MapleWIFI MR5100 and have the same issue. No factory reset in menu, the factory reset button beside the battery does not work. It looks like I can not use the router with any other service, what a scam. Their support now tells me that it is their firmware and will not provide any options. MapleWIFI sucks.
Datguy58
Jan 05, 2023Aspirant
I actually now offer the same unlimited service as Maplewifi for $130 a month if you are still looking for internet or I may be interested in buying your router to resell to one of my customers.
