gokusupa
May 18, 2022Follower
Mr1100 nighthawk M1 will not factory reset
Nighthawk MR1100 M1 No factory reset option is available under settings No ability to update firmware Holding reset button for 5,10,20,30,60,120 seconds yield no results, the custom settings re...
stevef4571
Jul 11, 2022Aspirant
I thought the same was happening to me..
but then realized I was doing it wrong. I was removing the battery.
When I left the battery in, and had the device turned on, while holding the reset button for 10 seconds, then I could see the factory reset sequence on screen and it worked.
Datguy58
Jan 05, 2023Aspirant
Unfortunately that doesn't work on the Maplewifi routers. They have put a custom firmware on them and locked them down pretty good. I have only been able to fully reset 1 out of the 3 I have had so far
