broncosaurs's avatar
Oct 24, 2019
MR1100 Nighthawk Mobil Router "Added Ethernet standby timer settings"
Just loaded the newest firmware into the M1.  I can not find the setting "Ethernet Standby" to keep the ethernet port from sleeping.  The info on the new firmware says "Added Ethernet standby timer settings".  I looked thru the settings to find this.  Can anyone tell me where this setting now is located?  Was under setting/setup/ethernet standby.  Using the mobile router w/ dhcp pass thru to my home wifi router, I need the ethernet port to stay on.
  • Settings > Setup > Mobile Router Setup
    You should see Ethernet Standby towards the bottom of the page.
    • Can't see it too on EU model but seems that ethernet is always on, so maybe there is no need to have this future enable ?
  • bCruze,  not on the new firware.  At least not on the firmware I just installed.  Im going to conect tonight and see if the ethernet port goes to sleep or will it stat on keeping the main router connected.
