Viewpoint
Oct 28, 2019Aspirant
MR1100 Nighthawk no internet after firmware upgrade.
I have a 3 month old MR1100 that just updated to firmware 12.06.08.00. As soon as it rebooted with the new firmware it will only provide internet for 1-3 minutes until the connection says “no intern...
Blanca_O
Oct 29, 2019NETGEAR Employee Retired
Hi Viewpoint
Welcome to NETGEAR Community!
Please check APN profile settings as it may not have automatically setup the APN profile for your service provider. You can manually set it up via the WebUI and re-check connection.
Blanca
Community Team
Viewpoint
Nov 06, 2019Aspirant
I checked the APN settings and they are correct. It is detecting them fine. This 4 month old device is almost unusable after the newest update. Anyone have any other ideas? It always lasts longer after a factory reset, then when it starts problems, it won't last a few minutes after a reboot.
