Mariner10
Apr 21, 2020Follower
MR1100 Nighthawk PIN
Hi, I want to connect a periferal to my PC that has WiFi capability. It comes up under my connections so the PC and, I assume, the router are seeing it but to go any further I'm asked to provide the...
Lexsteel
Apr 22, 2020Aspirant
This sounds like WPS, you can either press the power button toggle through the info which should have the WPS pin, or connect another device log in through web browser goto setup and wireless there you should find the WPS pin
