Cuarzo
Jul 19, 2021Tutor
MR1100 Nighthawk Roaming Data Disabled
I have a new unlocked M1 nighthawk. I purchased a data-only SIM card from Verizon. I am getting the messages "Roaming Data Disabled" and "Mobile Broadband Disconnected" when I power on the device. ...
Cuarzo
Jul 19, 2021Tutor
addendum:
the router will connect to a Verizon tower and flash blue when in range, but the moment the router is out of range of a Verizon tower (and in range of a U.S. Cellular LTE network for example) the light switches to amber and "Mobile Broadband Disconnected"
- schumakuJul 19, 2021Guru - Experienced User
Cuarzo wrote:
: the router will connect to a Verizon tower and flash blue when in range, but the moment the router is out of range of a Verizon tower (and in range of a U.S. Cellular LTE network for example) the light switches to amber and "Mobile Broadband Disconnected"
Can you usually use for example a U.S. Cellular LTE network using a Verizon SIM?
Usually "roaming" is international (see the screenshot provided above) when you are abroad.
- CuarzoJul 19, 2021Tutor
Thanks so much for your reply. On my iPhone for example I have a T-Mobile data plan but when roaming in rural areas with no T-Mobile coverage it automatically switches to U.S. Cellular.
Yes, that's why I had asked - over here in Europe these kind of romaings are uncommon. Challenge Verizon if they support anything like this.... Guess you need to have roaming enabled for this, too.
