Cuarzo
Jul 19, 2021Tutor
MR1100 Nighthawk Roaming Data Disabled
I have a new unlocked M1 nighthawk. I purchased a data-only SIM card from Verizon. I am getting the messages "Roaming Data Disabled" and "Mobile Broadband Disconnected" when I power on the device. ...
schumaku
Jul 19, 2021Guru - Experienced User
Cuarzo wrote:
: the router will connect to a Verizon tower and flash blue when in range, but the moment the router is out of range of a Verizon tower (and in range of a U.S. Cellular LTE network for example) the light switches to amber and "Mobile Broadband Disconnected"
Can you usually use for example a U.S. Cellular LTE network using a Verizon SIM?
Usually "roaming" is international (see the screenshot provided above) when you are abroad.
Cuarzo
Jul 19, 2021Tutor
Thanks so much for your reply. On my iPhone for example I have a T-Mobile data plan but when roaming in rural areas with no T-Mobile coverage it automatically switches to U.S. Cellular.
- schumakuJul 19, 2021Guru - Experienced User
Yes, that's why I had asked - over here in Europe these kind of romaings are uncommon. Challenge Verizon if they support anything like this.... Guess you need to have roaming enabled for this, too.
- CuarzoJul 19, 2021Tutor
Thanks for writing back. I did talk to Verizon, they said there is no limitations on Roaming with my data plan, so I think it is a problem with the Nighthawk MR1100. Why does it say "Cellular Data Off" on the App screen for example?
Does roaming imply the international roaming, or the national roming where there is no coverage? Two very different things.
So you might have to enable roaming on the MR1100 to start with.
https://www.verizon.com/support/domestic-roaming-faqs/ (don't know if htis is applicable to your data only plan however) says "you need to enable data roaming on your device".
