Nawem's avatar
Nawem
MR1100 Nighthawk won't reset or boot
MR1100 won't boot up.  Orange light comes on, then logo, then after a few seconds both shut off.  It might do this several times, then quits trying. RESET seems to do nothing - multiple tries with and without power on!  By holding both power and reset I get a rapid blue/orange flash, then the screen read 'Downloading software update', but nothing seems to happen.  Pressing power button to start does nothing, but connecting it to USB power just enables the orange light and quit as above.  Is this thing pooched?
Can't log in to it because it is not producing wifi, and connecting with usb to laptop does nothing ...
No RepliesBe the first to reply
